redman02
- October 21, 2007
- Blaine, MN
- 2000 Sport (2-door)
Hey I could use some help here, need some direction:
2000 Explorer sport 4x4 (not sport track)
Couple questions:
1) On the tire chart here you show: 31x10.50x15 on 15x8 rim. I have stock rims on my 2000 Explorer Sport (not sport track) but are 16. On my stock Sport rims can I then put on 31x10.50 x 16 or is that not correct? I won't have a lift at this time and want it to fit. And if that is correct what tire size is that If I want to order some tires?
2) Later I might do the tt up front my self. But I would like to put on heavier leafs in the rear so the rear is a bit higher (1 inch higher) than the front to help when it is loaded down a bit when hunting. Does the back being an inch higher than the front cause any drive line concerns? I'm thinking a 1 inch TT up front and 2inch lift leaf in the rear.
And lastly could you help me with a link for a rear leaf kit for my 2000 Explorer Sport 4x4 about 2-3 inch.
thanks man it would help a bunch, Redman02
Couple questions:
