brianwsnc
- May 10, 2011
- Winston Salem, NC
- 2004 Sport Trac Adrenlin
Ok guys,
I figured I would ask the experts for help on this to see if anyone has done this before.
I installed HID lights, install was easy. low beam is nice and bright, white light
However, when I switch to Highbeams.. it switchs OFF the HID low beam bulb filiment and switchs ON the Halogen "high beam" filiment... which is not White, but yellowish..
I hate it, hard to refocus because of the changing color and brightness field is different.
I think IF I can wire the relay to leave the Low BEAM light when I use my High Beams, it will fix the problem
Has anyone ever done something like this or do you know which wires I should jump/switch/change to accomplish this?
Thanks!
Brian B
Thanks!
Brian B
