StangsandMavs
- January 30, 2009
- PA
Hey guys...
My 95 Explorer started to develop a grinding noise when the starter is engaged. It starts and ran fine otherwise...
So, I dropped the starter and inspected the flexplate teeth... there were a bit worn and perhaps slightly burred, but the vehicle has 210k on it, so I didn't think it looked real bad.
I went ahead and swapped out the starter, as it seemed to have some wear spots. I did notice that there was a "machined" surface on the old casing close to the shaft where the drive gear hits, about 1/8 inch wide.
As I put on the new starter, I noticed that it had no machine mark. I stuck it on and lo and behold, the noise was still there.
So, I pulled the starter back down and see that the new one now has a smaller version of that machined mark.
I re-examined the flexplate through the starter hole... rotating it the whole way... but still don't see anything.
It seems that the flexplate is too far away from the starter in the bellhousing to make those marks... obviously, shims can't fix that... so I'm left thinking that perhaps the welds around the ring gear broke that I haven't located yet, or there is a crack that has developed that is only exposed when the starter gear is engaged. Or the flexplate bolts to the crank have come loose...
All of which means I'm yanking the transmission...
Any other ideas?
Any other ideas?
