I wonder if this happens to you guys. If you have problems and since you have a problem and it's under warrenty, you'll bring it to the dealer, right?? Well, once you get there, the problem mysteriously disappeared and everything works like it's supposed to. Have you guys had experiences like this? Well, that's what happened.
This morning, before taking my truck to the dealer, I took my truck to a gravel parking lot to test out if the 4wd system worked. Well, here's what I did. I stopped the truck and put the tranny to neutral, switched to 4Low, put the tranny to reverse then pedaled to the metal. Well, the fronts grabbed on b/c I noticed the rocks jammed into one little pile on each side. But anyway, I took the truck to the shop and let them see if there's a problem with it.
The slipping tranny problem never appeared again. I also had the blend door problem. It happened once last week but never came back. The driver's power lumbar support never worked and this morning, it worked. Gosh, I hope these problems resurface again before the warrenty expired (1000 miles) so I don't have to drop a bunch of cash on these repairs. I gotta rant. Sorry.
