Walt75
- June 6, 2011
- Savannah Missouri
- 2006 Explorer XLT 4x4
Hi guys
I starter another threat about this and I couldn't find it and that is why I started this one. At first I would have heat going down the road by just warm heat then it would blower cold air few a few miles then go back to warm air. I went bought the blend door kit but haven't installed it yet. But my blend door or the actuator is bad. Going to change both of them because I can't turn it from heat to cald inside of explorer. This is what is weird about my explorer if the temp outside is 20 degrees or warmer the heater will run you out of it. It doesn't make since to me. I live in Northwest Missouri and drive a hour to work and like to have heat. I thought about removing the heater control valve to see if that would take care of my problem but don't know if both top heater hoses on the control valve goes together or not. could you guys help me out on this issue?
Thank You
Thank You
