steadyhand
- May 5, 2010
- Missouri
- 99 Mercury Mountaineer
Ok well I found another problem on my 99 mountaineer 5.0 that the previous owner neglected to fix.
The oil pan gasket is leaking and I do mean leaking badly. It has oil all over the cats and this could result in a fire if the cats got hot enough.
I don't like to let something go undone so it is time to fix it.
It looks like I have to lift the engine from what I've seen.
From what I can see, I could just drop the pan and squeeze a one piece gasket in there and seal it back up. BUT, I would like to pull the whole pan out and clean it up. It will allow me a chance to see what is inside of that oil pan. Hopefully nothing bad
Do I just loosen the motor mounts and tranny mount and jack up the engine several inches?
Do I have to unhook anything from the engine to jack/lift it up such as fuel lines, electrical plugs, exhaust, etc.?
