bruce119
- June 14, 2010
- Holiday, Florida
- '93 Explorer
93X 2wd A4LD I did have some overheating issues last year. I got that under control. I got a temp gauge in the pan. I only seem to have an issue when I run a long trip or run in stop and go for a long day. It will puke some fluid I thought I mite have it under control but it happen again the other day the temp on the trany got up to about 195 not over 200. But it has puked real bad before (3-4 months ago) 3-4 quarts to the point I couldn't drive.
Any thoughts, is it time for a rebuild I have 178,000 miles live in Florida. It's fine around town but I want to go to N.C. in the mountains but I don't trust the trans. It doesn't leak a drop once the puking stops dripping.
I thought I read the A4ld when it overheats pushes fluid out a vent on the top of the trans.
So some thoughts and input...is there something I can do to help this I would think 200 should not cause it to puke fluid and it normally runs about 185. When stressed like a long hill or hard acceleration is when it mite get close to 200.
I have a 185 thermostat water temp is rock solid never goes over 185 now. Got a cooler and I run two 7" pusher fans in front of the oil cooler and condenser. Oh and of coarse problem only shows in summer when A/C is on.
Any help, ideas, explanations what is going on or should I start saving for a rebuild....
Thanks
Bruce from Florida
Thanks
Bruce from Florida
