Explorer Pete
- April 18, 2010
- Sacramento, Ca.
- 2013 Explorer Limited 4WD
Has any one replaced the shift lever, That would be the pot metel piece that the shift lever connects to. It is known that it will break and leave you stranded. Ford will charge you an arm and a leg to replace the steering unit. I was quoted around $875.00 plus labor. Most junk yards are asking about $200.00, just to pull a unit for you to do the replacing work. I am intersted it how you replaced the broken 1 with the new 1.
