Why not just wear your seatbelt, belive or not i could safe your life.
Turn to page 161 in your manual for instructions on how to deactivate BeltMinder.
Or:
One time disable
Any time the safety belt is buckled and then unbuckled during an
ignition ON cycle, BeltMinder will be disabled for that ignition cycle only.
Deactivating/activating the BeltMinder feature
Read steps 1 - 9 thoroughly before proceeding with the
deactivation/activation programming procedure.
The BeltMinder feature can be deactivated/activated by performing the
following procedure:
Before following the procedure, make sure that:
* the parking brake is set
* the gearshift is in P (Park) (automatic transmission) or the neutral
position (manual transmission).
* the ignition switch is in the OFF position
* all vehicle doors are closed
* the driver’s safety belt is unbuckled
* the parklamps/headlamps are in OFF position (If vehicle is equipped
with Autolamps, the Autolamps feature MUST be turned off.)
To reduce the risk of injury, do not deactivate/activate the Belt
Minder feature while driving the vehicle.
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT
START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately 1–2
minutes)
* Steps 3–5 must be completed within 60 seconds or the procedure will
have to be repeated.
3. Buckle then unbuckle the safety belt three times, ending with the
safety belt unbuckled. This can be done before or during BeltMinder
warning activation.
4. Turn on the parklamps/headlamps, turn off the parklamps/headlamps.
5. Buckle then unbuckle the safety belt three times, ending with the
* After step 5 the safety belt warning light will be turned on for three
seconds.
6. Within seven seconds of the safety belt warning light turning off,
buckle then unbuckle the safety belt
* This will disable BeltMinder if it is currently enabled, or enable
BeltMinder if it is currently disabled.
7. Confirmation of disabling BeltMinder is provided by flashing the safety
belt warning light four times per second for three seconds.
8. Confirmation of enabling BeltMinder is provided by flashing the safety
belt warning light four times per second for three seconds, followed by
three seconds with the safety belt warning light off, then followed by
flashing the safety belt warning light four times per second for three
seconds again.
9. After receiving confirmation, the deactivation/activation procedure is
complete.
Michael
???Buckle it.
He's saying buckling the seatbelt would "disable" the alarm. There's times when it bugs me, like the key-in-door-open dinging.
FANTASTICTurn to page 161 in your manual for instructions on how to deactivate BeltMinder.
Or:
One time disable
START THE ENGINE)
minutes)
warning activation.
seconds.
seconds again.
complete.
Michael
