wolfdog2rags
- April 3, 2000
All-
A while back there was a thread called 'whistle under the hood'. There were also a couple of other threads dealing with the same described symptoms.
I have been searching throughout various threads but never found results on a fix. Has anyone come up with a solution yet?
I have many of the same symptoms listed in the 'whistle under the hood thread' and have done the following to try to fix them.........
sprayed/cleaned throttle body
replaced tension pulley
replaced idler pulley
replaced fan belt
listened to bearings in water pump, alternator, other parts with bearings.
Our noise, 'chirp' or 'squeal' only happens when it's cool outside upon startup/warmup and then goes away within a couple of minutes.
Sure would like to fix this annoyance!
Thanks for your help!
Brandon.
replaced fan belt
Brandon.
