gluciano
- May 13, 2009
- Fort Lauderdale FL
- 95 Splorer XLT 2 WD 4L
95 X 4L that stalls once it's warmed up.
So far I have replaced the IAC, plugs, wires, seafoam, throttle body cleaner, air filter, fuel filter, water pump, thermostat. The old plugs did not show signs of any cylinder issues, just some carbon on it.
When cold or warming up the engine runs great, no misses no backfires no nothing. When it warms up it will idle at about 900-1000rpm and then all of a sudden die. There is no CEL that comes on when this problem happens. The way that I am able to get it started again would be to wait a few minutes, floor the gas pedal down as I am trying to start it. Once it starts up some black smoke comes out of the tail pipe and it smells like you're spraying the throttle body with throttle body cleaner. After it is started it takes a few seconds before it runs normal, it will sort of bog slightly. From there it will idle at nearly 2k rpm..
I have no idea where else to begin to look. It's hard to get a scan for codes because it's OB1 and Autozone does not do it for free like they do on OB2. Money is a bit tight right now so bringing it some where to have a scan is tough.
Any thoughts?
Any thoughts?
