crunchie_frog
- June 19, 2010
- Johnson City, TN
- Multiple 99-00 5.0 AWD
I have a 5.0 with 187,000 miles and it burned 1.5 qts of oil in about a month of mostly several short drives daily. It burns blue smoke on start up for a few minutes and then it clears up. I did a compression test and get 165-180 psi with similar, quick, even build up (3 strokes) to full pressure on all cylinders. I am thinking of just replacing the valve stem seals and see what happens. I am thinking though I may should just go ahead and do a valve job and head clean up while I am in there, but I really have no indication something is wrong with the valves/valve seats.
Anyone just replaced the valve stem seals for similar symptoms and had any long term success with reducing oil consumption?
Anyone think I should just go ahead and do the valve and head work while I am in there instead of just doing the valve stem seals?
Any concerns with using high mileage oil after replacing the valve stem seals? They have additives that swell/soften the seals and I did not know if this could harm the new seals.
Also, I looked for a write up on this in this forum and could not find one. Anyone interested in a write up when I do this, or maybe you know where there is a write up on this?
