pet575
- June 11, 2008
- Kansas City, MO
- 2004 Limited
In the past few weeks, I've noticed a loud and whiny noise when the engine is running. It is definitely tied to RPMS (louder with more RPMS, quieter when coasting) and it does it whether I'm in Park, Drive, or Reverse so I do not think it is transmission related.
I suspect this is either an alternator or water pump bearing that I'm hearing. But I've had alternator bearings and water pump bearings go out before, and this doesn't sound like the high-pitched "chirp" you normally get from those. This sounds more like an electric motor type of whine sound.
Anyone have any thoughts on what I'm hearing? I'm getting no difference in performance on my volt or temp gauges and have no coolant leaks. Is there any chance it could be a flywheel issue? Only flywheel issue I've ever heard was more like a grinding or ticking noise.
