Shaun123
- November 5, 2005
- Location
- Highway 90
- San Antonio, Texas
- 97 XLT SOHC V6 4.0 RWD
I need to know what would be the best way to wire up my audiopipe AP-2004 (4 channel 2000watt) Amp with my 4 8" Low / Mid Frequency Loudspeaker 8ohm 500 watt speakers
i read alot online before asking around but i want it done right the first time and i cant find a similar setup normally my other systems i had i would just connect them and not worry about it.
i allso have a Clarion EQS746 7-Band Graphic Equalizer
Size 8”
Power (P.M.P.O) 500 Watts
Power (R.M.S) 250 Watts
Frequency Resp. 65-6.000Hz
Sensitivity 95dB
Voice Coil 2“ Til
Mounting Depth 93mm (3.66”)
Impedance 8 Ohms
Magnet 35 Oz
Class AB Power Amplifier
• Built-in Variable High Pass & Low Pass Crossover
• RCA Line Input/Output Jacks
• Electronic Protection Circuitry to protect the amplifier
from short circuit, DC Offset & Thermal Overload
Share |
AP-2004
Channels 4 Ch Class AB
Power (P.M.P.O) 2000 Watts
Power (R.M.S) S 4 Ch-100W x 4@4Ω
S 4 Ch-115W x 2@2Ω
B 1 Ch-230W x 2@4Ω
Frequency Resp. 20Hz - 20KHz
S/N Ratio 95dB
Bass Boost 0-18dB @ 45Hz
Input Sensitivity 0.25V - 5V
Speaker Impedance 2Ω to 4Ω
Total Harmonic Dist <0.05%
Dimension (LxWxH) 384x176x55
http://www.audiopipe.com/products/loudspeakers/apmb/apmb-8bt.html
http://www.audiopipe.com/products/amplifiers/ap/ap-2004.html
http://www.clarion.com/us/en/produc...es/EQS746/us-en-product-pf_1259559424832.html
Size 8”
Sensitivity 95dB
Voice Coil 2“ Til
Impedance 8 Ohms
Magnet 35 Oz
Share |
AP-2004
S 4 Ch-115W x 2@2Ω
B 1 Ch-230W x 2@4Ω
S/N Ratio 95dB
