r37ribution
- October 7, 2004
- Ypsi/MI Y town! whoot whooot!!!
- 1996 "Sport" XLT 4.0L OHV
I currently have a 4.0L OHV sitting in my engine bay. I has 200k on it and a blown lower intake gasket.
I bought the gasket from Ford and started tearing apart the top of the motor when I realized the valve covers gotta come off. After seeing this I started thinking about changing springs, valves, lifters, rods, perhaps just replacing the entire heads with Alabama ones which I was quoted $185 a piece, upgrading to a 410 cam, etc. 'while I'm in there' when I realized I might as well rebuild/replace the motor since I would most likely blow a ring or a bearing after replacing all the upper half of the motor.
The gasket direct from Ford:
Which brings me to my question...should I rebuild the OHV or swap the motor?
Pros to the OHV -
-The most robust and reliable motor I have ever had the pleasure of provoking a controlled burn in.
-Better compression ratio for supercharing - If I kept the OHV I would rebuild with the intent of supercharging.
-Lifetime warranty on the 4r55e via Aamco.
Cons -
-Lack of an abundance in aftermarket parts (ie. heads).
-Lack of horsepower.
-A pretty expensive rebuild if done right ie. Creager's rebuild.
and this leads to further dilema - SOHC or v8?
Pros to the SOHC -
-lifetime warrany on my 4r55e with Aamco (they are in something like 40/50 states, very convient!) assuming the trans will bolt up to a SOHC.
-I shouldn't have to change the ECU (from what I have read the only difference is an additional sensor on the motor, can't remember what sensor. Perhaps a cam position sensor?)
-Better gas milage. This is a big one for me!
Cons to the SOHC -
-I would need to find one newer than an '03 or one with low milage and spend more money on rebuilding the timing chain tensioners.
-Higher compression ratios are not good for supercharging
-Lack of aftermarket parts??? I'm not sure of this one, I don't think it should be too much of a problem since the 245ci motor is now found in the non GT stangs, right?
Pros to the 5.0L v8
-Hmmm well it's a 5.0! I think we all know most of the pros to this motor.
-A better trans (not really an issue since I have the Aamco warrranty)
Cons to the 5.0L v8
-Loss of a $750 lifetime warranty.
-Gas milage!!!! It's my daily driver.
So what yall think?
Pros to the OHV -
Cons -
Pros to the SOHC -
Cons to the SOHC -
Pros to the 5.0L v8
Cons to the 5.0L v8
So what yall think?
