I hate you.
More specifically, I hate the fact that you can cover holes and make them appear as solid ground. Snow, you owe me. Thanks to you, I spent 30 minutes rolling around on you, only to find out that the bottle jack that Ford supplied was not ideal for the uneven surface which you masked. Your partnership with the ground forced me to waste another 30 minutes of my time while I waited on someone to show up with a floor jack and plywood. In addition to time wasted, I will most likely end up spending hundreds of dollars on new tires because 3 of my current tires are 60% worn and 1 is only 5% worn. This combination doesn't play well with my AWD system. Yes snow, I hate you.
I hate you.
I hate you.
