allmyEXes
- February 6, 2016
- No. Alabama USA
- 1997 Blue Ex 4.0 SOHC
- Callsign
- KAGG 3611 (CB)
I have a stock 1992 ford explorer 4x4 with a 4.0 liter engine and automatic transmission. It has 148,000 miles on it. It has been sitting 6 years with an empty and very dry fuel tank. The fuel in it now is 2 days old. I don't doubt that some parts made from rubber or electronic parts could have gone bad or are going bad from sitting several years
Here is what it has been or not doing.
In the morning the engine starts when cold every time without fail. Once the car is at operating temp and turned off, it has a slim chance of starting up again. The car cranks fine. starter, solenoid, battery and all that work fine. It peters out once I let off the ignition and the engine tries to take off on its own but it just can't. It sounds like it is going to start every time as in it turns over, but just sputters and nothing. After waiting until the next morning it will start. Once it decides it wants to run, it idles very roughly at first only. I give it some throttle to keep it going and it will eventually run. Once the engine gets going again it runs and idles fine. It absolutely runs 100%.
Any suggestions would be appreciated, but keep in mind the car runs fine once it has been started. So it has to be independent of the engine running mechanics and is temperature sensitive.
