Jody Breeze
- January 23, 2023
- Cleveland Ms 38732
- 96 Explorer XLT
4.0 OHV
Hello everyone. I see a lot of threads about stuck in 4 low. I'm having the same issue. I have 96 4.0 OHV 4WD and it has that axle disconnect on front axle that pulls a vacuum. 2 months ago I got stuck and tried to use 4WD but would not engage. Last year it worked all 3 times I used it but this year the one time I needed it I got nothing so I'm thinking I will look at it later as long as I have 2WD. Well before I could address the issue I was at car wash 5 days ago and I was leaving and crank the truck and it jumps into 4low on its own. I'm thinking I accidentally turned the 4WD switch because it was on the 4low selector but don't you have to have it in neutral with brake pressed before it will engage now it's hung up. I tried everything I read on here but still hung up. Please somebody help me out if you had this happen to you before.
