- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Moab: Yes!, remove your t case and have a look at the output shaft in the back of the trans, about 4" in where it begins to taper see if you have teeth marks from your t case input shaft. removing the t case in my BII is about a 2 hour job because things are so tight without a body lift and because the trans mount and floor shifter must come out to get access to the 5 bolts
Also if the t case does not go up against the tailhousing flush by hand (without the bolts) then you may have a problem... my AA adapter is the 7" version just FYI not the 9", I am not sure what the difference is. The guys who rebuilt my 4r70w last Friday showed me the wear and tear internally, not total kablooey so to speak but definatley not good, broken shims, washers, increased wear on drums, etc
CDW, my buddy Brett has been rebuilding his own A4LD's now for a couple of years, I have watched him collect the tools and learn the process, it now cost him about $5-600 to do a complete build just for parts/kit but they are coming out great! I would love to follow in his shoes, but time did not afford that luxury this summer.
Fingers crossed I am off to get two cases of Mercon, I really hope she holds together this time!
500 miles, then drain the pan & converter, 500 more miles then repeat and replace filter...you know the usual $200 in Mercon/filter routine LOL
All I know is she went together perfect this time, even though the V8 is a tight fit, I can put this puzzle together pretty well now, there are 3-4 bolts that really put up a fight, the two top bellhousing bolts, the inner bolt on teh pass side header flange, and the dipstick to engine bolt...wow there is no room for hands on those! instead I use some tape on the bolt head to hold it in the socket, then its just trial and error with a flashlight until its inserted and threaded...
