LOL, it’s even funnier you said you wanted to go with the extreme because I’ve actually had that muffler on my truck as well. It is a very loud muffler….almost sounds like I had no muffler at all. All it is is a single chamber muffler with a triangular wing in it. It was so tiny. The casing itself I believe is 11” long. It got too loud for me so I ended up going with the flowmaster original 40. Dumped, I liked the muffler. Its deep, and sounds A LOT better than past mufflers I’ve had (Flowmaster SUV 50, Flowmaster Super 40, Flowmaster Super 44, IMCO Xtreme). One thing we need to clarify as we speak is you have the OHV motor, I have the SOHC. Your motor tends to sound a bit deeper than mine….mine is known to sound “higher pitched”.
With that said, my current exhaust system consists of
Stock manifolds
2.5” Offroad Y-pipe
Single 2.5” high-flow spin-cat ceramic converter right after the Y
Single in/out 2.5” Flowmaster original 40
2.5” tail pipe
All piping is mandrel bent
This setup sounds the best to me and I am 110% happy with it. When I added the tailpipe, it toned the sound down a bit, but added deepness and the “chambered” tone. I will say that, and this usually happens with most V6’s, above 3k it does lose the chambered sound and sounds more like a solid voooom sound. If I floor it, it just gets loud. Not 4 cylinder buzzy, just loud. And while I am on the note of 4 cylinder loud, when I had the offroad Y pipe without the high flow cat, It was REALLY LOUD. When I floored it, it sounded like a pissed off bee…smelled bad too. My current set up, which is above, is my favorite of all and I don’t think I will change it. I was debating going to go with the (at the time it was IMCO, but cherry bomb bought them out) Pro series muffler or the flowmaster original 40 and I went flowmaster because I am a fan of the chambered sound. I will get some high quality clips sometime soon. This set up is loud, but sounds good to me. I def. recommend anyone who does this to run a tail pipe because it really does add that chambered sound over a dump. Got to love V6’s….
