CmdrPopNFresh
- November 10, 2008
- Salt Lake City, Utah
- '93 Sport
hey guys. i donno if anyone has an ex this new on here but i thought id post anyway. this is right off the ford broadcast messages page.
2065 - 2008-2009 EXPLORER/MOUNTAINEER AND SPORT TRAC EQUIPPED WITH 4.0L ENGINE BUILT PRIOR TO 11/6/08 - POTENTIAL HARNESS CHAFE AT THE PCM BRACKET
SOME 2008-2009 EXPLORER/MOUNTAINEER AND SPORT TRAC'S EQUIPPED WITH 4.0L ENGINE BUILT PRIOR TO 11/6/08 MAY EXHIBIT A NO CRANK, CRANK-NO START, DRIVEABILITY SYMPTOM, OR IDLE CONCERN WITH OR WITHOUT MIL ILLUMINATION/DTC'S DUE TO THE PCM ENGINE HARNESS CHAFFING AGAINST THE PCM MOUNTING BRACKET. THIS HARNESS CHAFE TO GROUND CAN ALSO RESULT IN BLOWN FUSES. FOR NO-CRANK ISSUES CHECK FUSE F8 IN THE SJB. FOR ALL OTHER SYMPTOMS CHECK FUSES F4, F39, AND F43 IN THE BJB. USE THE PTS WIRING DIAGRAMS TO ASSIST IN ISOLATING SHORTED CIRCUIT. IF A CHAFE IS FOUND, FOLLOW CONNECTOR REPAIR PROCEDURES, CELL 5-1, FOUND IN THE PTS WIRING DIAGRAM. REPOSITION THE PCM HARNESS TO PREVENT FURTHER CHAFFING. IF VEHICLE EXHIBITS DIAGNOSTIC TROUBLE CODES(DTC) P035X-P0360 FOLLOWING REPAIRS REVIEW OASIS FOR UPDATED COIL PRIMARY CIRCUIT DIAGNOSTIC ROUTINES.
