jeepgirl
- October 28, 2008
- Nevada
Please help. I read a thread about headlights going out, and I just want to make sure I am headed in the right direction. Both of my headlights went out yesterday...both headlights and the DRL function. At night, the dash cluster lit up and parking lights were on, but no headlights. My understanding is that it is either the fuse or the switch (but not the dial switch on the dash). Does this seem like a good starting place? Which fuse might be the culprit, and where is the switch located? From the pictures in the thread, it appears as though it is in the steering column on the left side. Should this cost about 30 bucks? If I should try to do this switch replacement myself, is there a reasonable possibility that I could discharge the airbag or should I be ok? Thanks very much for the input. It is much appreciated.
