I'd expect the ausie to be much tigher.
I "think" that is what tbars is running and he just "loves it" when he tries to run the ditches in truckhaven.. lots of backing up. I think its better now that he uses an AGR pump.
I went with the trac-lok LS since it was cheap.. and I'm going to be adding another clutch disc to it (factory has one spot with 2 steel plates next to each other). This should make it tighter.. Hopefully not too bad, but I know a single locker in the rear just isn't enough anymore.
~Mark
Do you have any more info on your front LS? A link maybe? How much? do they have it in a standard rotation? I would have tried to get one if I knew someone made a LS for the front on the Ford D35.
I ran LS's in front and back for years, and lots of people thought I had lockers. Now that I do have lockers, it's a lot tougher doing tight turns on the trail.
I recommend the Detroit TruTrac. It's a gear driven LS, and much tighter (a good thing) than the Ford TracLok.
The lowest ratio I've been able to get is 4.56. I've had requests out the rear for 4.88 and 5.13's. I just can't get them. I was told they don't make them and never have..
do you remember how much you paid for yours?it looks like i can get an aussie for the front around $239
http://www.offroadlockers.com/item.php/TM4efe0a/85b8/06/306012/.html
