thanks for the info so the bronco springs will give me how much lift they advertise? i thought it would be less because they dont have as much ppi as ttb springs so the 4" would be 3" on a ttb?
It'll probably be a hair more than what's claimed for the Bronco due to differences in how the springs are mounted, however I wouldn't be paying any attention to that... If you want the best chance of everything coming out right on, you really should do what's needed to get the exact specifications required for the springs you need, and then try to match that up as best you can with what's available .
Being that the amount of movement a modded TTB has from full droop-to-ride height is usually in the neighborhood of 5"
at the spring perch, you want a coil that will compress around that amount when the vehicle's static weight is put on it (if yours has more or less than that, you of course can adjust the figures accordingly).
As an example:
Say you weigh the front of your truck by driving it onto a scale, and it reads 2400lbs. Subtract approx 350 to get the amount of weight the springs will be supporting (2050lbs... This is your 'sprung' weight, which is minus the axle & wheels).
Also factor in the TTB beams (acting as levers) have roughly a 1.5:1 ratio of leverage against the springs.
2050 ÷ 2 = 1025lbs (sprung weight each side).
1025 × 1.5 = 1537.5lbs (amount of pressure on the coil).
Suppose your prospective coil has a rating of 320PPI...
1537.5 ÷ 320 = 4.8" (amount the coil will compress under 1537.5lbs of pressure).
Stock coils sit at 10.5-11" tall with weight on them, so for 4" of lift, you're looking for a coil that will sit at 14.5-15".
15" + 4.8" = 19.8" (free length of the 320PPI coil you need).
The coils in the first link I gave should work in this example when used along with a 1.3" spacer (which your lower spring mount will likely become about that tall anyway after the modifications needed so it clears the upswept part of your beam where the knuckle is).
Yes, it certainly it would be nice if the lift industry would figure out all this crap for us and offer us a ready-to-go kit (instead of sticking us with the uber-stiff TTB coils that they do), but until they do, we're forced to do it on our own (re-engineering a suspension for more flex is unfortunately not a matter of simply sticking some random parts to it).
