AGreenSmudge
- April 23, 2013
- DFW, TX
- 1998 Eddie Bauer Explorer
Alright guys, I was replacing the upper and lower intake gaskets today and had everything back together only to find that the tube that comes out of the side of the intake tube from just behind the MAF sensor that runs around under the throttle body and has a rubber plastic piece that comes up and attaches to the tube coming out of the base where the idle air control valve is. The rubber plastic piece had torn wide open and as a result the air it draws in for idle doesn't come through the MAF and the engine won't idle as a result.
I cannot find any reference to this part or a part number. Not even on ford parts.com
