cklinejr
- September 6, 2009
- Golden, Co
- 94 EB
[Question] My A4LD rebuild (no Forward only Reverse)
I know there are a bunch of great threads on rebuilding the A4LD (GREAT threads by Glacier991) but please bear with me.
My issue was that I only had Reverse, no forward AT ALL. There are a few posts on here asking what might cause it, most unanswered.
So here we go.
First off, these things are not easy to get out. Granted mine is a 4x4 so the transfer case added some grief, but still - those bellhousing bolts at the top? prepare to run to the store to pick up more then a few socket extensions. (I actually picked up a wobble set from Harbor Fright Tools for just a few bucks)
Finally out
I fully expected to see metal in the pan. (and was very happy when I didn't, though I should have changed the trans fluid when I bought the truck...)
Start with removing the Low Reverse Servo cover, Detent Spring, and then the Valve body
After wiping the oil from the Low reverse servo cover I was left with a buildup of gunk, it was almost dry packed in there.
Photo for referencing solenoid wire hookup
VB bolts loosened
Here's the "Bolt Board" I put the Valve Body bolts on to keep them organized
Then mounted it on the engine stand
The next items I consider a must have to maintain a level of sanity:
1) Large print outs of the exploded view
2) A nice clean work area
Oh, and the bags. Those are a MUST.
More to come.
-Charles
So here we go.
Finally out
VB bolts loosened
More to come.
-Charles
