nole99
- February 15, 2003
- Phoenix Arizona
- 2001 Explorer Sport
*UPDATE*Clunk and Rattle from front wheel well area
I have a clunky sound coming from the front wheel wells that baffles me. It is a loud clunk and rattle heard stronger in the pass side and can be felt through the foor boards. This sound is heard mostly at low speeds when traveling over almost any uneven pavement.
This sound is beginning to concern me because at times it sounds as if the wheel is gonna come right thru the floor.
My rig is still under warranty and in the last 2 weeks I have had the drivers upper ball joint and arm replaced, the sway bar bushings and end links replaced and an alignment done. Slip Yoke was greased and all tires were just balanced Sat. I only get a slight vibration around 65 but it goes away by 70 at 75 the driveline seems much louder and far less smooth than it was say 3 months ago.
My rig has 85K miles on it and this clinky rattle noise started off very faint about 2 months ago and has gotten very loud in the last 4 weeks.
My concern is that the shop says that every looks okay and they cannot see anything .... but when we ride we can hear it.
Tonight I removed my front bumper just to rule out that as the culprit.
I can feel this thru the floor .... please any ideas are greatly appreciatted ... I drive alot for my biz and often have clients in my rig so safety is job one and then the annoyance factor.
Do you think if I take it to the dealer they might have more pull with the warranty co. or should I just demand the warranty co send an adjuster to the shop to hear for himself .....
I am at my witts end
TIA
TIA
