Hey all. Went through and changed cam sensor and cap, changed crank sensor also, same code. Reset TPS to .78v and idle is better. Will usually stay running fine, sometimes needs a little help on first startup.
Seems like problem occurs when decelerating, truck will have slight hiccup, drop rpm to say 500rpm then quickly recover to ~750-800rpm. Every so often it would have a slight fluctuating sound on very very easy accelerating, not quite a hiccup but something different than normal for sure. Had a slight hiccup once when cruising at 50mph and converter locked up, dropping rpm's. Dropped, then had a small hiccup. Couldn't get it to replicate issue again. Seems to run fine when you're on the gas or leaving from a stop at a little faster than normal rate. Not sure what else to do. Wire looms look good, not crushed anywhere, no burns spots, no open wires, just had transmission out last week changing converters, had upper intake off and inspected harnesses. All seemed well. Really getting discouraged over this damn code.
Only thing left on that circuit to change is the ECT sensors and connectors; already changed coil pack ground to an even more solid connection to harness, don't think coil packs would be bad as that would cause a very noticeable misfire. They have maybe 6k miles on them. Plugs and wires have maybe 1500mi
