4x4xbrian.com
- October 20, 2006
- Location
- Watkins Glen Ny
- Watkins Glen Ny
- 01 ranger
- Callsign
- Btilden
I engine swapped my ranger using a 2000 explorer 5.0. All wire harness and components are from explorer. The speedo and cruise are not working now and it shifts hard AF, all was good prior to removing stuff from the explorer.
The abs does work so I would assume the rear sensor is functioning properly.
Heres the big question:
With live data scanner I see an accurate speed signal at the pcm, could this be read from the oss? Or does this confirm that the vss signal from the abs module is working correctly?
Abs codes: C1095, C1939, P0500
Thanks in advance
Thanks in advance
