smcmoran
- March 14, 2011
- Medford, NJ
- 2000 Explorer Limited
Good evening all. I'm almost stumped and could used a fresh set of eyes(or brains) on my issue. Its a 00 Explorer limited, 5.0 AWD, 182kmi. runs great when it cranks. This has happened a couple times and its always at the worst possible time. You try to start it and there is nothing but a relay click. The lights do not dim, but the radio and other accessories turn off as they should. So far I have changed the battery, starter, battery terminal, neutral safety(range switch) and each time the truck started cranking again. The first couple times it was the battery connections, and they looked a little corroded. The last one was the neutral safety which was very stiff and its lasted about 4 months. Today my wife ran an errand and came home, the truck we up to temp and then sat for about 2 hours. She then went to go to work and nothing. Got lights and radio, showing 12.4v on the battery but nothing.
I tried jumping it with a hot box, different keys, arming and disarming the alarm, unlocked with the door code, and nothing. When I replaced the neutral safety, I thought that was my last idea. Now I am wondering about the battery cables themselves. I find it hard to believe that corrosion in the cable would drop the voltage enough. Also it seems too abrupt. Almost like the voltage has hit a threshold and now won't engage the starter.
Let me know if anyone has any ideas as I am at the end of my proverbial rope. Next steps are going to be replacing the battery terminals again, with some high end units I purchased a while ago and probably replacing the Battery cables(looks like fun) What I hate is the unknown, I really want to know what is causing it to NOT turn over.
Thanks in advance!!!
Scott
Scott
