Id there s step by step procedure for spring over axle?
I installed mine over a weekend without air tools but I did need a torch and a breaker bar with a few extensions. Aside from those the only thing I did not have that I had to run out and buy was a pipe wrench to hold the body mounts while removing the bolts
Caught a picture of this beast on my game came a couple nights ago. Finally got a clear picture the next day.
I have no idea where to start. I understand the principle behind shackles and blocks on the rear suspension, But I don't understand the front lift at all. Forgive my ignorance. I just need somebody to point me in the right direction and lay it out there for me plain jane style.
Torsion twist the front will give you about an 1.5" of clearance from what I've read... I'm doing it on mine for the taller tires I'm getting.
Thanks. It does. I just want a little height. I feel like when I looked at the leaf springs yesterday, they were on top of the axle, which is possible that the previous owner did some slight modding as there is a trailer braking system in the rig. But who know except the daylight tomorrow. Thanks for your help.If you're trying to cut costs, ditch the rockstars. They don't look that great on smaller trucks unless you're running 35s and even then they're over used. Personally I like the MB wheels TKOs I used to have on mine.
Anyway on to the lifts. If you are 4wd you can twist the torsion bars to give you up to 2" of lift. Whatever you do, don't go more than 2". And don't worry it looks like a lot more when you set the truck back down. Now thats free except you will need to get an alignment afterward.
The rear is pretty easy to lift as well. You cannot use blocks on these trucks to lift them because the leaf springs are under the axle. If you used blocks it would lower the rear. Instead you can get Warrior Products #153 shackles they will give you ~ a 2" lift in the back. Those will run you about $80 unless you find someone selling theirs for cheap.
The other option for a mild lift is doing a Performance Accessories 3" body lift. This does not affect the suspension at all but is more involved to install and also will cost somewhere around $250.
Also you can do both like I and a lot of others have done and fit 33s or 35s like a couple of us have. If you click on the link below (in my signature) that says my registry you will see pictures of just the TT/Shackle lift and then the body lift with 35s and I think it's all on the 1st page if I remember correctly.
Hope this helps
And AAL will help with sagging springs.
No issues with sagging. Though it may be good for pulling the boat. anybody know the cost of adding a leaf?
$37 from Amazon. I didn't have any problems with sagging springs when I did mine, I just liked the long term effects of this versus the shackles.
I agree. Long term AAL is better. It won't negatively arch your springs. It's a matter of unbolting the U bolts instead of just the shackle bolts but either way is very easy.
