01 Sport Trac Headlights/Fog Lights Will Not Turn On | Ford Explorer - Ford Ranger Forums - Serious Explorations
jimiexp80
Orlando, Florida
2001 Explorer Sport Trac
2001 Sport Trac
Headlights & Fog Lights will not turn on. When I turn the headlight switch, the highbeam indicator comes on, but no high beams. Dash lights/parking lights/indicators all work.
When I hit the fog light button to the right of the radio, the light that indicates the fog lights are on does not come one.
I have checked/replaced every fuse that references headlights/fog lamps.
I have replaced the multifunction switch & the headlight switch, but no luck.Both wire harnesses for the multifunction switch, and the headlight switch look to be in good order. No real corrosion or wear and tear is visible.
I have not replaced the headlight bulds, because I would not think both bulbs, and fog lights would go out at the same time.
I have not replaced any of the relays under the hood. In the owners manual there is no reference to headlights, but there are two fog light relays: Fog Lamp Isolation Relay & Fog Lamp Relay.
Any thoughts? I am at a loss.
