jbarber18
- November 12, 2012
- MI
- 2001 Sport Trac
I have an 01 ST and recently (now that is getting cold out) I have noticed that my heat is not staying hot. I tested it at idle in the garage tonight, and it will go from hot to cold and back (about 5-10 sec cycle). I checked the heater control valve and it seems to be working ok. The temp gauge seems to stay at about 30% of the way up even after running on the highway for a while, so I am thinking maybe a bad thermostat, but if that was the case, wouldn't the heat just stay luke warm, not fluctuate? Some also mentioned a plugged heater core or blend valve issue, but neither make sense with the hot/cold cycle as it is. Anyone have any experience similar or other ideas? I hate to just start trying parts to try parts.
Thanks in advance all!!
