Today I removed the rear diff cover. I saw no damage to the spider gears, ring or pinion. I found the button from the end of the axle and the "C" clip sitting on top of one another in deepest part of the bottom of the diff. They were in pretty good condition, considering. Both showed a single chew mark, but I don't know from which gears. I would assume from the spiders, but there was zero indication of any damage to the gears. It looks like the button and "C" clip dropped out of the side gear and straight down into the bottom of the diff case. Although there were some metal shards in the passenger side axle tube. the center was clean as a whistle, so I assume the driver's side axle tube is also clean.
In examining the broken button, it appears it just broke off the axle. This really puzzles me. After all, that axle survived in another Explorer for over 100,000 miles w/out breaking. Maybe it was somehow damaged by the salvage yard... who knows.
While removing the cross-pin the cross-pin lock bolt gave me quite a hard time. I was using a new 8mm wrench, but it still wanted to strip the head of the bolt. I tried heating the cross pin, but the damn bolt just wouldn't come loose. I know from prior experience that you're screwed if you can't get that bolt out. In desperation I grabbed my 1/4 socket set and found that the 5/16 size fit pretty well. Better the the 8mm box wrench. I heated the carrier case up real good and put a short cheater pipe on my 1/4" ratchet. The bolt finally came free. It will not be reused!
Is it actually a 7.5MM head on that bolt? I'm beginning to believe it is... If so that would explain while my 8mm wrench was slipping. Now I gotta try to find a 7.5MM box wrench I guess.
http://www.cjponyparts.com/rear-axl...m_medium=cpc&utm_campaign=EbayCommerceNetwork
So it looks like I will need:
A new axle w/axle bearing and seal ($130)
New cross-pin, lock bolt, "C" clips (I don't trust the old ones) ($32)
3 Qts Valvoline 80W90 regular hypoid gear oil ($20)
Replacement brake shoes (free AZ warrantied)
** Total around $185 - I'm not spending any more than I have to on this POS
