mjonesjr84
- August 6, 2015
- Salem, IN
- 02 Ford Explorer
I've got an '02 Limited that the heat stopped working. The heat worked great all winter until we started using the AC. Today it was cool and when I tried to use the heat, it blew cold.
I have ran the EATC self check and returned no codes. That should eliminate the blend door actuator. There is antifreeze in the reservoir. The engine does not over heat and gets to proper temperature so I'd say the thermostat is working fine.
Anyone have any ideas?
