BlindViper
- August 23, 2007
- York, PA
- 2011 explorer limited
I thought it was the sunroof but its not. When I pulled the carpet on the floor everything was soaked. When I had a hose on the windshield I could see a single stream of water coming down the firewall. But there is some sound insulation that covers the area making it impossible to see where it is coming from. I pulled the cowl covers and the wiper motor assembly. When I put the hose in there the water still leaks inside. The drain is clear for the cowl. Now here is my question in the cowl area there is a "panel" with a bolt and a stud. I removed the bolt but it would not come off. My thoughts were to run a bead of sealant around this panel as I feel this is the only place for it to be entering the car. Thoughts?
