02exp4Rap
- September 12, 2016
- Rockville MD
- 02 Explorer 4.0
Crawled to home at 30mph max. Died every stop but restarted but shaky .Accelerator response was little to none.
Code pulled: p0340, p1151, p1309, p0171, p0300, p1131
Action taken per suggestions of the members here on same like situation:
1. Changed CMP - no changes
2. Changed alternator due to some members stated that defective voltage regulator will cause p0340 - no changes
Removed valve covers and found the driver side camshaft timing chain was broken - snapped, cut. Right side and main chain were OK. The timing chains was replaced over a year ago and I only got less than 10K miles. It was made in China.
Now my question: Can the valves and pistons contact when the crankshaft timing chain breaks? I asked this because I plan to fix it if fixable.
Thanks,
Gerry
Thanks,
Gerry
