kalabherdiya
- August 28, 2013
- Salt Lake City, UT
- 2002 Ford Explorer XLT
I just found the solution to a problem on my 02 Explorer, and wanted to post the story here, in case someone is having the same issue. I have found solutions to several problems on this or other forums, so wanted to share my problem and solution.
My truck was blowing fuse #15 under the hood, causing me to lose power windows, interior lights, radio, and all instruments. After much troubleshooting, I found that when the key was on it would never blow the fuse. Any time the key was in the accessory position, the fuse would blow instantly. If no key in the ignition, the fuse would blow if the door was open. You real experts out there have already probably figured it out, but it took me a little while. The problem was a short in the puddle light (the light under the driver's side mirror). Thus, it was only blowing when in accessory mode, not when the key was "on".
