Zdude
- September 16, 2013
- Raleigh, NC
- 2002 Explorer
Last week, I pulled out of my apartment complex and stopped at the next stoplight. When the light turned green, I tried to accelerate, but the car would not move (engine rev'd, but apparently tranny not engaged). The car was in drive, but the 4x4 Low light had lit up on the dash. I shifted into neutral and tried to put the car back in 4x4 Auto but the buttons would not respond. I tried multiple times, shifting back and forth between Park, Neutral, and Drive. If the car was on, and I put it in Park, it made a ratcheting sound. However if I turned the car off and then shifted into Park, there was no noise and "Park" was engaged like it should be. I removed the key, looked around outside, saw nothing, then put the key back in and turned the ignition. The car started up fine. There was no 4x4 light on the dashboard, so I shifted into drive, felt the transmission engage, pressed the accelerator and the car accelerated like normal.
Any thoughts? Thanks in advance for any assistance!
