02 explorer xls won't go into passing year | Ford Explorer Forums - Serious Explorations
gtice100
NC
2002 ford explorer limite
When I go to pass at any speed engine rev to about 4g and won't down shift then I have to give less throttle it will then shift back to higher gear .it shifts just fine except to pass no codes
First thought is TPS but that usally will set a code. you may have to get it hooked on a scanner and have it driven and monitor inputs and output signals and go from there. Let us know what you find. Good luck
