02 Sport Trac XLT Sunroof Only Goes Forward and Backwards a Few Inches
Durvelle27
Memphis, TN
02 Explorer Sport Trac
Hey what's up guys, new member here. I have a 2002 Ford Explorer Sport Trac XLT that I have owned about 10 months now. The Sunroof has never worked since I bought it but now I decided that I want to fix it. All fuses are good and all windows function just fine. I pulled the console down and noticed there is no power at the switch and there are some wires cut. I was hoping someone could help me identify the cut wires so I can get this fixed.
Update: I was able to rewire in the new motor and a new pigtail. The motor seems to be fully functioning but once installed the roof only goes forward and backward a few inches. It doesn't fully open
Durvelle27
Memphis, TN
Can someone with a sunroof just pull down their console so I can see a picture of the wires
Mbrooks420
High Voltage.
1998 Mountaineer AWD
Like like they were cut and taped. You probably have a bigger issue than the wiring.
Durvelle27
Memphis, TN
It looks like the person cut the Sunroof motor pigtail
If I had a picture of it I can resolder them back in
Mbrooks420
High Voltage.
And then you will probably have to fix the original problem.
Durvelle27
Memphis, TN
So i was able to get a pigtail rewired in along with a new motor. Motor is functioning well but now the issue is the Panel only goes back a few inches forward and backward
