meadowofbones
- June 18, 2019
- WHITETHORN
- 2003explorerXLT 4.0 v6
2003 explorer v6 sohc 4wd. I am having a crank no start issue. I was driving and it suddenly died no sputtering or warning lights. I was able to restart without a problem. It continued dying over and over again until I was able to get it towed home and off of the trailer and now it will not start. I am getting spark . I can hear the fuel pump kicking over and I can also get a sufficient amount of fuel to spray out of the Schrader valve though I don't have a fuel pressure gauge.. the engine still does not start even with starting fluid directly into the throttle body.I have also inspected the coil pack and there are no visible cracks.i cleaned the MAF sensor. I did replace the fuel filter as well as the fuel pump relay but neither of those things helped. I am not getting any codes besides the p1000 finish drive cycle because I had disconnected the battery. I also changed the pck sensor. Any suggestions would be much appreciated. ......also there is no slapping noise and it seems to be cranking at the usual speed though I am getting no rpm movement except a delayed jump after trying to start. Thanks.
