Maxim63
- July 12, 2020
- Stamford, CT
- 2003 Ford Explorer 4.6
My 03 Explorer 4.6 is idling super high 2800-3000 rpm upon start up and does not come down, I can not even put it into gear because it’s reving so high. So far I have put a new intake manifold, iac, tps, maf, egr valve, egr pressure sensor, 4 o2 sensors, cylinder head temp sensor, pcv, all vacuum hoses , removed cleaned and lubed throttle body, smoke test (no leaks), did a battery rest All and still no change, the issue came out of no where it was running like a champ and one day I parked and when I restarted it was idling high and i barley made it home. No DTC’s I’m all out of ideas any chance you guys can point me in the right direction
