Dino360
- August 14, 2018
- TX-Texas
- 2004 Explorer Eddie bauer
My 04 Eddie Bauer has a jumper wire that bypasses normal ac operation by tapping into the relay in the relay box under the hood to hot wire the compressor. My climate control panel on the dash was displaying ext temp of 107° all the time so I replaced it with another one and now seems to be displaying the correct temperature.
The issue I was having is that the ac compressor being wired that way makes it run constantly whenever the truck is running. I am not able to shut it off by selecting off on the control panel and since it's running all the time, it freezes up the evaporator after about 45 minutes of driving.
My scan tool only reads the signal for the external temp sensor and not the test of the ac system. I took it to a mechanic that has a better scan tool and he tells me they're getting a failed to communicate error when trying to read the ac codes and that they are getting a code for the ac control module. They're telling me that the control unit needs to be programed to the truck. Does this sound right to anyone? If so is that something a dealer needs to do?
Thanks for any help
Thanks for any help
