kryhavoc
- April 19, 2016
- Location
- Tampa Fl
- Riverview florida
- 2003 Exp; 1998 Exp
Gents,
I have a 2003 4.0 SOHC that i have recently completed timing chain surgery on. Engine is back in and works with no codes at all. Now that i remembered the coil is 123 465 for the wiring. Dumb mistake on my part which had me chasing a misfire for far to long for my ego.
Codes were cleared and KAM was cleared twice with complete driving cycles between them in an attempt to get the computer to relearn the engine.
Now on to driving results. When the engine is first started in the morning cold the power off the line and through the gears seems normal. Once the engine reaches operating temp it seems to be "lacking" something in the lower RPM range. I swear it feels like my 98 Cummins diesel truck did when i had driven it in town on too many short trips. I had to take it out on a longish drive (45 minutes or so) and really heat it up to blow the carbon out of it and wow... back to normal. Thats what this explorer FEELS like to me today and yes for giggles i did try the "Italian tune up" i read about on these forums.
I have the Forscan program and an OBDII scanner with graphing capabilities and have looked at everything and maybe i am blind but i can't really see anything wrong.
I have replaced/cleaned/worked on the following very recently mostly as a result of pulling the engine and replacing all the timing chains.
New Platinum plugs - Autolite and gapped correctly
New 8mm silicone sparkplug wireset
New air filter
New driver side catalytic converter (and successful back pressure test)
New knock sensor
New EGR valve (old one had a blown diaphragm)
Replaced the coil pack with a junkyard sourced one... it was very new looking
Cleaned the intake manifold runners and IAC valve while they were off.
New PCV valve and rubber tube
New Intake gaskets and i tested for leaks with intake cleaner and watching the OBDII graphs.
Cleaned the original MAF sensor then replaced the MAF with a cleaned junkyard sourced unit.
Replaced the Crank Position sensor
Replaced the DPFE EGR sensor.
Fuel pressure checked... 65Lbs and very steady looking on my new guages
Compression test completed and 170Lbs across the board for each cylinder.
Cleaned the fuel injectors in a bath of berrymans fuel cleaner for about a week.
Replaced the thermostat housing with new 195 degree thermostat and all gaskets. I did reuse the ECT sensor but it does not leak at all and reads the expected 196 degrees when engine is running.
I probably have other stuff i have worked on but left off this list.
I am positive i have an issue left that is holding the engine back from producing normal power when it is at operating temp... but i have no idea where to look anymore. Any thoughts would be appreciated.
New air filter
New knock sensor
