03 explorer sport no hazards at all and no right turn signal when marker or headlights are on
Garrett Stevens
West Milton
2003 explorer sport xlt
I have a 03 sport and I have no right turn signal when marker or headlights are on the indicator on the dash comes on but it doesn't blink and the left turn signal works all the time I have LEDs in and have the proper relay for them but I have no clue where to start to fix this issue
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
Do the hazards function appropriately? Adjust your tilt wheel all the way up, and down, and retry in both positions.
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
+1. Steering wheel in the UP position relieves tension in the MFS connector.
2003 Sport Trac Steering Column Wiring Repair (Click link below)
Wayback Machine
Garrett Stevens
West Milton
The hazards don't work at all and I tried to tilt the column up and down and it still didn't fix it
Garrett Stevens
West Milton
Mbrooks420
High Voltage.
EF Vendor
Did they work and just quit working with no changes being made?
They worked after changing to LEDs?
When you say relay, do you mean flasher module?
Garrett Stevens
West Milton
Yes the system worked perfect after I changed to LEDs and I changed out the relay not the module so it doesn't hyper blink but just yesterday it started having the symptoms listed above and I put the LEDs in about 5 months ago
M 2002 Explorer Sport 4WD 2 door Stock 2002 - 2005 Explorers 0
G OEM electric fan on 2003 explorer sport Stock 2002 - 2005 Explorers 1
G 2003 Explorer sport 2dr 4wd Leaf spring Stock 2002 - 2005 Explorers 3
M 02 explorer sport rear wiper motor Stock 2002 - 2005 Explorers 2
S 2003 Explorer Sport Trac Coolant Leak Stock 2002 - 2005 Explorers 4
T Troubled 2003 Explorer Sport Stock 2002 - 2005 Explorers 4
B 2003 Explorer Sport 129k keeps dying, but restarts Stock 2002 - 2005 Explorers 6
J What is better explorer xlt or sport trac? Stock 2002 - 2005 Explorers 18
J 2002 explorer sport 2 dr pedal assembly Stock 2002 - 2005 Explorers 0
T 2003 Ford Explorer Sport XLT (2Door) Stock 2002 - 2005 Explorers 4
R Is engine in 04 Explorer and Sport Trac the same? Stock 2002 - 2005 Explorers 6
K Explorer "SPORT" vs Sport Trac Breaks Stock 2002 - 2005 Explorers 4
C Why Sport trac engine not compatible with Explorer Stock 2002 - 2005 Explorers 2
R Question on 2002 Explorer with Sport Package Stock 2002 - 2005 Explorers 3
O 2002 Explorer Sport AC evaporator core Stock 2002 - 2005 Explorers 2
N 03 Explorer Sport XLT - HELP Stock 2002 - 2005 Explorers 4
W 2002 Explorer sport front wiper motor replacement Stock 2002 - 2005 Explorers 1
H 2002 Explorer Sport Fuel Pump ????? Stock 2002 - 2005 Explorers 7
R 2004 ford explorer sport trac flasher Stock 2002 - 2005 Explorers 1
G 2003 Explorer Sport O/D Light Flashing - After O/D Sprag Replacement Stock 2002 - 2005 Explorers 0
L Any advice for longevity? New to forum and to Ford - 2003 Explorer Sport XLS Stock 2002 - 2005 Explorers 2
P Anyone know a cheep explorer sport trac accessories website?? Stock 2002 - 2005 Explorers 6
T 2003 Explorer Sport Fuel Pressure Stock 2002 - 2005 Explorers 3
R Explorer Sport (2 door) V6 4.0L Oil Leak Stock 2002 - 2005 Explorers 3
M 2003 Explorer with 2004 Sport Trac Motor Stock 2002 - 2005 Explorers 1
K what differential do you have in a 2004 ford explorer/ or sport trac Stock 2002 - 2005 Explorers 4
R 2002 explorer sport swap 4speed auto trans' Stock 2002 - 2005 Explorers 0
R 2002 explorer sport SWAP Trans' Stock 2002 - 2005 Explorers 2
D 2002 Ford Explorer Sport Brake Fluid Stock 2002 - 2005 Explorers 1
T Deciding between '03 and '04 Explorer Sport Tracs. '03 is $8.3k, '04 is $10k Stock 2002 - 2005 Explorers 5
S 2002 Ford Explorer Sport, Wheel/ Rotor problem Stock 2002 - 2005 Explorers 1
A 2005 Explorer Sport Trac cluster interchange ?'s Stock 2002 - 2005 Explorers 1
C Computer Module location in 02 Explorer sport Stock 2002 - 2005 Explorers 0
M Explorer vs. Sport Trac Stock 2002 - 2005 Explorers 6
L 2005 Explorer XLT Sport Driver's Power Seat broken Stock 2002 - 2005 Explorers 1
E How to Turn of keyless entry on 2003 ford explorer sport Stock 2002 - 2005 Explorers 5
S 2005 Explorer XLS or XLS Sport Stock 2002 - 2005 Explorers 3
0 Hood for 2003 Explorer Sport XLT Stock 2002 - 2005 Explorers 6
V 02 Explorer Sport-Wrong type injectors Stock 2002 - 2005 Explorers 0
T 2002 explorer sport brake lights/front flashers Stock 2002 - 2005 Explorers 3
R 03 explorer sport 4.0 engine replacement Stock 2002 - 2005 Explorers 3
J Explorer Sport Trac Engine Identification Stock 2002 - 2005 Explorers 1
0 2003 Explorer sport 2 door ( Rear Brakes) Stock 2002 - 2005 Explorers 3
A '03 Explorer Sport stereo replacement Stock 2002 - 2005 Explorers 4
C 2002 Explorer 4.0 SOHC swap using 04 Sport trac 4.0 Stock 2002 - 2005 Explorers 4
S 2002 explorer sport rear hatch handle wont open Stock 2002 - 2005 Explorers 0
E lower my 2002 ford explorer sport Stock 2002 - 2005 Explorers 4
E 2003 Explorer Sport-Right Brake light does not work and turn signal doenst blink Stock 2002 - 2005 Explorers 4
M 2002 Explorer Sport Wind Shield Wiper Problem Stock 2002 - 2005 Explorers 1
A 2003 Ford Explorer Sport Fails to Start Intermittently Stock 2002 - 2005 Explorers 1
Similar threads
