03 explorer trans | Ford Explorer Forums - Serious Explorations
03 explorer trans
Steven S
Lagrange
2003 Eddie Bauer
O/D light started flashing....replaced transmission (used)...still flashed and sluggish in 1st with no OD....replaced PCM and re-set codes for relearning....OD still flashing, still sluggish in 1st and still will not hit 4th or OD....any ideas?
What are the current codes?
P0713 is for the temp sensor and the P1788 is for the pressure control solenoid B, both are within the solenoid block assembly.
I would inspect the connection at the case connector for corrosion or missing or bent pins, if all ok I would suspect the solenoid block itself.
Check for debris in the pan before buying anything.
