allmyEXes
- February 6, 2016
- Location
- Lickskillet
- No. Alabama USA
- 1997 Blue Ex 4.0 SOHC
- Callsign
- KAGG 3611 (CB)
@410Fortune Jamie, Question: In relation to the ABS delete, could a resistor of equal value to the resistance of the bulb filament be plugged into the bulb socket and keep the chime off?
I may have been making a mistake with these 4.0 SOHCs when it comes to oil changes. Sometimes at our local Wal-Mart, FL1A filters are not available and I will settle for a Fram PH8A. I recently read something oil viscosity and filters. It is quoted from another internet user.
"Unless you designed and built the engine yourself. Use ONLY the oil viscosity the engineers that actually designed the engine to use recommends. Chances are they know more than you about their engines they designed and if you do so choose to go against their recommendation you cannot be upset if an engine failure results. NEVER use Fram or Champion-labs (STP, BOSCH, MOBIL1, K&N) oil filters. Use only Motorcraft oil filters for all Fords. All other filters do not have anti-siphon drain back valves and will cause premature engine damage usually resulting in broken timing chain tensioners and cam phasers."
I have been using 10W30 in place of 5W30 which I hope is ok, however I think that I need to go get a FL1A filter and get the Fram off of the 4.0 SOHC. Any additional thoughts?
