03' Ford Explorer NO heat or AC
reamer7
KS
03' Explorer
I have an 03' Explorer I replaced the blend door actuator in January. It is now June I went and got in the truck after work and started it up and had no air what so ever. I checked heat, defrost, and A/C got nothing. Checked all fuses and relays and they are all good. I am just not sure if it is the blower that has went bad or if something else has failed? I need help cause it is hot here in Kansas and it will be another cold winter without heat too.
