WARNING: Secure the transmission to the transmission jack with a safety chain. Failure to follow these instructions can result in personal injury.
NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms can occur while the vehicle relearns its adaptive strategy. The customer needs to be notified that they can experience slightly different upshifts either (soft or firm) and that this is a temporary condition and will eventually return to normal operating condition.
NOTE: If disassembly or installation of a new transmission is necessary, drain the transmission fluid. Install the drain plug when finished.
With the vehicle in NEUTRAL, position on a hoist.
Disconnect the battery ground cable.
Remove the radiator appearance cover.
Remove the LH upper fan shroud bolt.
If equipped, remove and discard the assembly screw(s).
Remove the upper fan shroud bolts.
1 Remove the RH bolt.
2 If equipped, remove and discard the RH assembly screw(s).
3 If equipped, disconnect the A/C line retainer.
4 Remove the fan shroud.
If equipped with a 4.0L engine, remove the exhaust manifold to Exhaust Gas Recirculation (EGR) valve tube.
If equipped with a 4.0L engine, tap the hole in the RH cylinder head in order to install the lifting hook.
Use a 10 x 1.50 mm (0.06 inch) tap to tap the hole.
If equipped with a 4.0L engine, install the special tool in the previously tapped hole.
If equipped with a 4.6L engine, remove the engine appearance cover.
If equipped with a 4.6L engine, remove the battery ground cable and the bracket.
Position the bracket and wire harness out of the way.
If equipped with a 4.6L engine, install the special tool.
Install the special tools.
Remove the front and rear driveshafts.
Illustration 1 of 3. Remove in the order indicated.
Illustration 2 of 3. Remove in the order indicated.
Illustration 3 of 3. Remove in the order indicated.
If contamination is present, backflush and clean the transmission fluid cooler.
Item 13: Transmission Assembly Removal Note
Install a suitable jack stand under the transfer case.
Item 36: Torque Converter Nuts Removal Note
NOTE: Make an identifying mark on the nut, stud and flexplate to allow for correct installation. Remove the four torque converter nuts.
Item 42: Solenoid Body Harness Connector Removal Note
NOTE: Clean the area around the connector to prevent contamination of the solenoid body connector. Remove the screw from the solenoid body connector and disconnect the connector.
Item 47: Fluid Cooler Nuts Removal Note
CAUTION: Do not damage the cooler tubes. Hold the transmission case fittings with a wrench. Disconnect the transmission cooler tubes.
Item 48: Transmission Assembly Removal Note
WARNING: Secure the transmission to the transmission jack with a safety chain. Failure to follow these instructions can result in personal injury. Support the transmission with a transmission jack.
Remove the jack stand from under the transfer case.
Item 50: Fuel Line Bracket Removal Note
Position the bracket and fuel lines out of the way to gain access to the other transmission retaining screws.
Item 52: Transmission Assembly Removal Note
Vehicles equipped with a 4.6L engine, remove the front crossmember.
Vehicles equipped with a 4.6L engine, remove the seven engine-to-transmission retaining bolts.
Vehicles equipped with a 4.0L engine, remove the six engine-to-transmission retaining bolts and position the fuel line bracket out of the way.
Lower the transmission and transfer case as an assembly from the vehicle.
Install the special tool.
NOTE: If the transmission is being serviced, the transfer case will need to be removed. Remove the transfer case from the back of the transmission.
Remove the screws and the bracket.
Disconnect the vent hose.
sorry dont know how to add the pics
